Forums >> Revit Building >> Technical Support >> how do you make this wall boundary ?
Thu, Apr 13, 2006 at 2:46:29 AM | how do you make this wall boundary ?
Petsagouris
This is a problem I am facing .. please look at the attached .jpg and tell me how do I make a wall that has the boundary shown.
Fri, Apr 14, 2006 at 3:54:43 AM | RE: how do you make this wall boundary ?
eldados
eldados Avatar
4.5 Stars: 8 Votes
can't access the jpeg for some reason...
Integrator
KarelCAD
Fri, Apr 14, 2006 at 5:20:53 AM | RE:
Petsagouris
Quoting eldados - 2006-04-14 03:54:43
"can't access the jpeg for some reason..."
Yep me too...
Anyhow it is a non-rectangular wall in plan. ( its faces aren't parallel... )
Fri, Apr 14, 2006 at 7:46:15 AM | RE: how do you make this wall boundary ?
rkitect
rkitect Avatar
4 Stars: 29 Votes
Pets, host the image on tinypic.com and post the link here. That should help till revitcity gets it's act together.
Sat, May 6, 2006 at 5:34:36 AM | RE: how do you make this wall boundary ?
zouzou
a way of doing this could be: Go to modelling, then click on create a wall, solid form , by extrusion, where the depth will be the length of the wall, define the z axis, and then describe the section of the wall in one of the elevation views. Untill you can find an easier method you can use the file attached,
Structural column doesn't define room boundary (but only sometimes!)
Wed, Apr 1, 2015 at 10:23:56 AM
Area Boundary Lines - R2015
Thu, Apr 14, 2016 at 2:22:27 PM
Interior Elevation Boundary Lines
Mon, Nov 24, 2008 at 10:35:26 AM
stair boundary
Mon, May 16, 2016 at 4:51:31 AM
Fixed boundary wall along topo surface
Tue, Jul 31, 2012 at 6:10:24 PM
Page generation time: 1.5218
