Forums >> Revit Building >> Technical Support >> Grid's automatic scaling
Thu, Sep 22, 2016 at 5:28:56 AM | Grid's automatic scaling
unnbe
Hello everyone!
hmmmm... when I scale my project  1:100, the grid's tag become too big! I would like to modify the "amount of increasing" related to the scale. How to figure it out?
Thanks.
Thu, Sep 22, 2016 at 5:55:21 AM | Grid's automatic scaling
Elnazer2
4 Stars: 5 Votes
the grid size isnt view specific which means that it doesnt change size when you scale the view it always remain with same size ( the printed size on paper will always be the same ) and that works perfectly for consistentcy , that on all the package the grids will always have the same size , so choose the size 1 time and make sure thats the desirable size you need to be printed,
Hope this helps and here is a similar thread with same topic :
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28096
Thu, Sep 22, 2016 at 6:51:51 AM | Grid's automatic scaling
unnbe
hmmm.. I'm sorry Elnazer2, I don't realize. You say: "it doesnt change size when you scale the view". So, why I'm experiencing the opposite? That is, when I change the scale, the grid's tags enlarge or become smaller (as for text or dimensions)... and this affects the print too?!
Thu, Sep 22, 2016 at 7:01:31 AM | Grid's automatic scaling
Elnazer2
4 Stars: 5 Votes
no what i mean i doesnt change size ( Scale ) is that it have the same printing size ... what i mean if you use a grid type for a 1:100 plan and used the same grid type for a 1:200 plan and put both on the same sheet , both grids will have the same size , actually when you change scale only the model elements are Scaling and grids ( dimensions , spot elevations , ....etc all annotations ) stay with the same size while everything else is smaller thats why it appears like grids are bigger .
Thu, Sep 22, 2016 at 7:28:02 AM | Grid's automatic scaling
unnbe
Ahhhhhhhhhh! Ok, ok! Now, I understand.
Then, to modify the size of the tags, I can only modify the family? For Dimensions, for example, there are much more parameters editable directly within the project than for Grids.
Thu, Sep 22, 2016 at 7:46:55 AM | Grid's automatic scaling
Elnazer2
4 Stars: 5 Votes
if you are using the default grid family you can modify it from the project browser , go to the project browser >>> find under families >>> annotations >>> your bubble Grid Family ( the deafault one is called (M_grid head) , open the types inside of it , right click on the one you want to change and go to type properties .
Noting that Changing the bubble size will change the printable size , which is in all views .
Thu, Sep 22, 2016 at 8:31:58 AM | [Solved] Grid's automatic scaling
unnbe
Great!
I thank you so much
2'x2' Diemsional Grid
Wed, Feb 5, 2014 at 2:10:47 PM
Schedule Grid is not showing up property
Sun, Apr 19, 2015 at 4:19:52 AM
Scaling dwg's in families
Wed, Dec 16, 2009 at 10:37:41 AM
scaling of level head, grid heads etc
Thu, May 25, 2006 at 6:07:37 PM
Automatic Scaling on Sheet
Thu, May 9, 2013 at 5:28:11 PM
Page generation time: 1.2973
