Forums >> Revit Building >> Technical Support >> Revit 2015 Solid Cut Fill Pattern
Wed, Sep 21, 2016 at 3:49:00 PM | Revit 2015 Solid Cut Fill Pattern
tmassey
tmassey Avatar
I have exhausted this so here goes. Two of our over all Vertical Circulation sections are not showing the solid fill pattern. In the floor or wall assembly properties every cut fill pattern shows in view except solid. If we cut a new section through the building all the solid hatch patterns show view template driven or not.
In these two sections we have checked, phase filters, cut fill pattern in the assembly, graphic overrides, scales coarser than, checked our View template seetings, applied no view template to the view, far clipping, VG filters. Model category visibillity, VG detail level.
I understand that this probably needs to be seen in the actual model to decipher I was hoping someone knew what I was missing.
There is nothing we can see that is overridding the solid fill not to show. Cheers
Using Revit Architecture 2012
Thu, Sep 22, 2016 at 8:27:54 AM | Revit 2015 Solid Cut Fill Pattern
Recut the section.   If that's ok then maybe the view was corrupted then simply copy/paste all annotative elements.
Could this be a view scale issue with the pattern?   Enlarge the scale and see what happens.
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:47 AM
Solid Fill Pattern
Wed, Jan 9, 2008 at 1:55:24 AM
Wall Solid Fill Cut Pattern Jagged on PDF
Fri, Apr 3, 2015 at 10:36:32 AM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Page generation time: 1.6037
