Forums >> General Discussion >> Revit Project Management >> Survey CAD file with large coordinates
Wed, Sep 21, 2016 at 4:53:52 AM | Survey CAD file with large coordinates
archie456
3 Stars: 1 Votes
Hi,
I'm creating a Revit model of a house and have recieved the CAD survey of the site.
The Revit file is created close to the Revit origin (I've not moved the survey point at all).
The CAD survey is created to OS coordinates, and so the units are very large - i.e. the survey is a long way from the AutoCAD origin.
I know there are issues with Revit and large coordinates - but does this affect CAD file?
If the AutoCAD survey is linked select centre to centre will and then moved a new metres will Revit be happy with that.
Does the large coordinate issue only affect Revit, and not CAD file linked into it?
Thanks.
Wed, Sep 21, 2016 at 10:36:25 AM | Survey CAD file with large coordinates
The problem does not affect the CAD file, the problem is the CAD file in Revit.  I like to open CAD files like yours, then select everything and write them out to a new file with a closer origin.   The only problem with this is possible updates.  If those are possible, make sure you pick and origin that you can pick again if you need to.
Survey Point and UTM coordinates
Mon, Jun 20, 2016 at 3:50:02 PM
Toposurface - CSV import to shared coordinates
Thu, Aug 22, 2013 at 2:59:54 PM
What is the correct workflow for Referencing drawing to Survey point??
Wed, Apr 29, 2015 at 7:10:51 AM
REVIT / CAD Coordinates
Wed, Jul 2, 2014 at 9:55:19 AM
Shared Coordinates while linking Dwg into Rvt
Thu, Jun 5, 2014 at 12:06:32 PM
Page generation time: 0.5502
