Forums >> Revit Building >> Technical Support >> Exterior wall color diagram
Sat, Sep 17, 2016 at 11:54:27 AM | Exterior wall color diagram
clickster
clickster Avatar
I'm working on a project with several different cladding assemblies (window wall, masonry, curtain wall, metal panel, etc). Some have been modelled using curtain walls, some have been modelled as regular walls. I am wanting to create a simple elevation diagram that assigns each cladding type a color... so that consultants and the contractor can have a map of where all the different systems are.
Is there some sort of visibility setting in revit that would easily do this? Something that would allow me to assign a given wall type a solid color. Visibility graphics would not work, because I've got multiple curtain walls that need to be assigned to different colors... I would need to do this by the wall type name. I looked in Filters, but couldn't see anything that would change the color of the object.
Any help you can give is appreciated.
Fill what is empty. Empty what is full. Scratch what itches.
Sun, Sep 18, 2016 at 12:31:51 AM | Exterior wall color diagram
Elnazer2
4 Stars: 5 Votes
i think your only solution is to use filters under visibility graphics , assign a filter for each type of walls with its name and give it a specific color .....
True color rendering
Wed, May 16, 2012 at 8:08:33 AM
Massing Attachments
Wed, Jul 12, 2006 at 3:14:26 PM
Exterior finish on wall not exterior enough... ?
Fri, Jun 3, 2011 at 8:44:28 PM
roof detail after exterior wall
Thu, Apr 1, 2010 at 11:34:56 PM
Lighting fixtures not against exterior wall face
Mon, Sep 8, 2008 at 1:24:09 PM
Page generation time: 0.7765
