Forums >> Revit Building >> Technical Support >> sheet index (list) not organizing properly
Thu, Sep 15, 2016 at 1:23:49 PM | sheet index (list) not organizing properly
ledgewood33
I am having some issues with my sheet index not organizing the sheets properly. I have parameters set up to do so and these same parameters are being used in other projects and working properly. for some reason there are two sheet that are not following in order and when I add a new sheet and apply those parameters to it they do not follow in order.I am attaching a screen shot of the schedule so you can see what I am talking about
Thu, Sep 15, 2016 at 3:26:54 PM | sheet index (list) not organizing properly
Post an image of your schedule sort and header settings.
Thu, Sep 15, 2016 at 3:29:56 PM | sheet index (list) not organizing properly
marmiketin1
4.5 Stars: 10 Votes
It appears you have those sheets organized under different disciplines
Thu, Sep 15, 2016 at 4:13:55 PM | sheet index (list) not organizing properly
ledgewood33
I found the answer in another forum. somehow the "discipline" became null and so I gave each of them a "discipline" of architectural and then they went in order. once there I made the "discipline" blank again and they continued to stay in order. and they were at the top of the list like I wanted them.
Sheet / Drawing Index / List Check Box
Thu, Dec 18, 2008 at 8:48:15 AM
View List and Sheet Index
Wed, Nov 24, 2004 at 6:58:59 PM
Links to each sheet in sheet index
Sun, Aug 21, 2016 at 11:06:31 AM
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:13 AM
SHEET INDEX ORDER
Sat, Dec 12, 2009 at 9:14:52 AM
Page generation time: 0.4752
