Forums >> Revit Building >> Technical Support >> Dimension Override
Wed, Apr 12, 2006 at 2:50:02 PM | Dimension Override
same
Does anyone know if it is possible to override the dimension text and substitute (or add) a word -- such as "Equal" or "Clear" or O.C.?
Wed, Apr 12, 2006 at 3:17:15 PM | RE: Dimension Override
TomDorner
4.5 Stars: 25 Votes
You can add a suffix or prefix to a dimension. Just check the properties box of the dimension to add. You cannot however "over-ride" a dimension. This has been dicussed ad-nausim on this forum and on AUGI. You can place a piece of masking style text over the "dimension" or I will submit my 2 cents that then what you have is not a "dimension" at all rather an annotation. If you want things to be "equal" then click the "eq" blue text of the dimension string and Revit will space the items equally and replace the dimension to report "Equal". Tom Post edited on 2006-04-12 15:18:50
Dimension Override with numbers?
Mon, Feb 7, 2011 at 3:29:50 PM
Dimension Text Override [ 1 2 3 ]
Wed, Apr 24, 2013 at 4:16:15 PM
34
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Dimension Override
Wed, Feb 16, 2011 at 2:26:16 PM
how to override values of level grids?
Thu, Jul 5, 2012 at 3:53:59 PM
Page generation time: 0.1127
