Forums >> Revit Building >> Technical Support >> Export Linework colors to DWG
Tue, Sep 13, 2016 at 7:39:56 AM | Export Linework colors to DWG
xzavoral
Is there any way to keep colors in DWG export from Revit (2015) as i see them in view? I can print PDF but when i export DWG it changes colors according to the settings. So is there a setting to keep everything as i see it - meaning everything is black except some LINEWORK changes to red color (highlighted changes in project)
Wed, Sep 14, 2016 at 12:04:12 AM | Export Linework colors to DWG
Elnazer2
4 Stars: 5 Votes
there is a way but it doesn't work perfectly there is n option in the exporting dwg setting color , turn it to true RGB colors , you will have the right colors .
Note that :sometimes hatches ( From floor materials filled regions etc....) hide some important lines. and it works perfectly with colored regions as materials and color schemes but with linework sometimes it doesnt work.
Edited on: Wed, Sep 14, 2016 at 12:11:23 AM
Help: Export in sheet colors to Dwg
Thu, Aug 15, 2013 at 2:15:51 PM
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
REVIT 2013 - Export DWG Layers Text File Location
Fri, Aug 3, 2018 at 4:44:52 PM
3d Export Format
Thu, Nov 30, 2006 at 4:25:34 PM
Export to CAD - Colors
Mon, Mar 3, 2014 at 7:37:38 AM
Page generation time: 0.8712
