Forums >> Revit Systems >> Technical Support >> Surface Pattern on Modified Floor - No Skewing for Floor Plans
Sun, Sep 11, 2016 at 6:40:30 PM | Surface Pattern on Modified Floor - No Skewing for Floor Plans
bitslap
Hi, I am a landscape architect using floors for both hardscape and softscape.  It is working well but I find that surface pattern hatches come out skewed because of the various slopes across the floor.
Is there a way to project the surface pattern from a certain angle or similar, so that hatches are consistent across the floor?
Sun, Sep 11, 2016 at 8:59:33 PM | Surface Pattern on Modified Floor - No Skewing for Floor Plans
bitslap
Okay the problem has changed.  I have a drafting fill pattern that still skews (on floors with modified subelements) when changing fill pattern settings to 'orient to view'.
This happens in new projects with simple drafting patterns.
Mon, Sep 12, 2016 at 10:10:25 AM | Surface Pattern on Modified Floor - No Skewing for Floor Plans
Sorry but patterns - both model and hatch - will act strange on warped surfaces.   Patterns work from an origin and a baseline.  We have wished for sometime that we could have patterns that drape over surfaces but not yet.  I don't believe they will in  CAD either.
Mon, Sep 12, 2016 at 7:45:11 PM | Surface Pattern on Modified Floor - No Skewing for Floor Plans
bitslap
Thanks WWHub.
Is it possible to make surface pattern IGNORE of the floor slope?
Fri, Jun 21, 2013 at 7:15:46 AM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Floor pattern -- masking floor pattern
Mon, May 23, 2005 at 11:51:48 AM
Column Shading in Floor Plans
Tue, Jun 15, 2010 at 5:06:27 AM
Inconsistent Floor pattern for shape edited floors
Thu, Sep 13, 2007 at 11:30:11 AM
Page generation time: 3.8699
