14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Aligned dimensions
4 Posts No Rating |
Is there a way to dimension between 2 points that are neither horizontal nor vertical to one another. In autocad this is done with the aligned dimension feature, but the aligned feature in Revit seems to insist that you select lines that are parallel, rather than allowing, for example, 2 corners to be chosen.
You can select the endpoint of a wall or object by hovering over it and "tabbing" until you see the blue square indicating the endpoint of something. Revit 9 out today will let you dimension to non-parallel objects. You can also add your own reference planes as well to get things to dimension the way you want.
HTH
Tom
Aligned dimensions on non-orthogonal walls |
Sun, Jun 11, 2006 at 8:16:11 PM
Aligned dimensions for centering curtain wall door |
Fri, Dec 23, 2011 at 6:26:40 AM
aligned acting like linear (up-down, left-right) |
Tue, Dec 6, 2011 at 4:00:40 PM
Aligned Dimensions Shift While Moved |
Mon, Dec 12, 2011 at 12:43:41 PM
Radial dimensions won't display but linear will? |
Thu, Jan 23, 2020 at 2:09:01 PM
