20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Varying roof thickness by slope change
I am currently using Revit 2015, and cannot seem to find a fix for my roofs. Revit seems to be displaying roofing materials thicknesses as a vertical measurment regardless of slope as opposed to perpendicular to the roof face. I attached an image I just did up quickly showing 3 roofs, varying slopes, low slope and steep slope. I used the exact same roof type for all 3, but you can clearly see the the different thicknesses. Does anyone have a solution to fix this? I feel as though it should be a simple setting change but I do not see an option anywhere. Thanks!
Revit doesn't do what you show when you do a roof sketch. You need to show us your roof properties and tell us your process. Are you doing these as extrusions?
I took a snip of each step in creating the roof. See attached images.
In the first step I use roof by footprint. Drew a 60x60 square. Added a split line off-center to create different slopes and set the height to 15'. I'm not sure if I'm missing a step or doing something wrong but I get the warning message often.
I attached the roof properties and assembly below
The same (one wall) to have varying thickness in its width dimension not height? |
Thu, Mar 1, 2012 at 10:17:43 AM
Roof with variable thickness on sloping framing |
Wed, Jan 20, 2010 at 10:12:06 AM
Wall Thickness variable |
Tue, Apr 12, 2005 at 11:37:44 AM
Change in rafter thickness in roof |
Wed, Jan 6, 2010 at 7:28:23 AM
creating subtle slopes for a flat roof in Revot 2011 |
Tue, Mar 8, 2011 at 8:26:33 AM
