Forums >> Revit Building >> Technical Support >> Schedule curtain panel by level?
Thu, Sep 1, 2016 at 4:41:27 PM | Schedule curtain panel by level?
clickster
clickster Avatar
I have a 42 story tower model. The facade has been modeled using curtain walls, each modelled on a floor by floor basis (42 curtain walls stacked on each other).
I'm trying to create a curtain panel schedule which totals the area of my glazed panels, on a level by level basis.... but when I'm creating the schedule, it doesn't seem like there is a way to tie each panel to the level it appears on (even though each panel sits whithin a curtain wall that has a unique level base constraint)
Anyone know how I could create a schedule which ties levels to curtain panels? Please help!
Fill what is empty. Empty what is full. Scratch what itches.
Fri, Sep 2, 2016 at 2:06:46 PM | Schedule curtain panel by level?
sllana
5 Stars: 2 Votes
it doesnt say "level" but "base constraint"
Fri, Sep 2, 2016 at 2:43:00 PM | Schedule curtain panel by level?
clickster
clickster Avatar
silana,
FYI, there is no option to add a "base constraint" field in a curtain panel schedule.
Fri, Sep 2, 2016 at 3:23:37 PM | Schedule curtain panel by level?
sllana
5 Stars: 2 Votes
u must use wall schedules, there u have that field. curtain walls are walls
Fri, Sep 2, 2016 at 3:30:17 PM | Schedule curtain panel by level?
clickster
clickster Avatar
I am not trying to schedule the curtain wall, only the panels within the walls. I want to create a schedule that lists all the panels within a curtain wall and gives the total area (for each level)
Fri, Sep 2, 2016 at 3:44:27 PM | Schedule curtain panel by level?
sllana
5 Stars: 2 Votes
then use "material takeoff schedule", (two lines below "schedule cuantities" there u have system panel field. And you can add in the comments of curtains the level where they belongs to
Edited on: Fri, Sep 2, 2016 at 3:46:18 PM
Edited on: Fri, Sep 2, 2016 at 3:47:35 PM
Edited on: Fri, Sep 2, 2016 at 3:48:03 PM
Fri, Sep 2, 2016 at 3:50:35 PM | Schedule curtain panel by level?
clickster
clickster Avatar
ok... but this method requires me to select each panel and add a 'level' comment.  I can't understand why the panel would not be tied to the base constraint of the host curtain wall.
Fri, Sep 2, 2016 at 3:53:04 PM | Schedule curtain panel by level?
sllana
5 Stars: 2 Votes
Do this: select all the curtains in a floor, then filter the selection checking only panels, add to the instance comments field the level where they are and then make the takeoff schedule.
Fri, Sep 2, 2016 at 3:58:40 PM | Schedule curtain panel by level?
sllana
5 Stars: 2 Votes
there's nothing to understand, actually, but programs are not perfect, so you must  use them the best way you can.
And no, you dont have to select panel one at a time, you can do it all at once in a 3d front view for instance and add the comment all at once too
Fri, Sep 2, 2016 at 4:40:25 PM | Schedule curtain panel by level?
clickster
clickster Avatar
ok, yes thank you, I will do that.  for your responses
Filtering curtain panel schedule by type
Mon, Nov 4, 2013 at 9:10:40 AM
curtain panel door not reading completely in schedule
Thu, Jun 30, 2011 at 1:56:58 PM
CURTAIN PANEL TRICK -- HELP!
Fri, Nov 30, 2012 at 2:05:27 PM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Multi-Category Material Takeoff - Curtain Wall as Curtain Panel
Tue, Oct 11, 2016 at 5:53:46 PM
Page generation time: 1.7420
