Forums >> Revit Building >> Technical Support >> Stair Command
Wed, Aug 31, 2016 at 3:19:06 PM | Stair Command
lkemnitz
I keep getting an error message when I try to open the stair command.
The message reads
A serious error has occurred. The current action has been canceled. it is strongly recommended that you save your work in a new file before continuing.
How do I correct this error or get around it?
Wed, Aug 31, 2016 at 3:32:54 PM | Stair Command
marmiketin1
4.5 Stars: 10 Votes
Are you working with a central file? Are you working in that central file or in a local file? I would suggest you open your central file from revit with the 'detach from central' box checked at the bottom. Then save that file as a new central file in a different location. Check to see if the stair command works. If so then you can start using the central file you just created and create local copies from that.
the promises of the new stair command in Revit Architecture 2013
Fri, Dec 14, 2012 at 9:17:29 AM
Stair Flexibility // Rotate Command
Sat, Nov 13, 2010 at 7:48:04 AM
modifying stair problems...
Wed, Oct 24, 2012 at 4:47:13 PM
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:19 PM
How can I create a split stair without multiple and separate stair components?
Tue, Jan 5, 2016 at 5:32:53 AM
Page generation time: 1.0144
