17 Users Online (15 Members):
Forums >> Community >> The Studio >> Two monitors
When rinning Revit on two or more monitors, does revit look like one big screen or can you put different project in each screen?
My boss is thinking about getting me four monitors.
anyone.
I don't have any experience with multiple monitors in revit, but I would imagine the revit program would act however you have the monitor output set up. If you have the output set up to make 4 monitors into 1 large screen then it will be 1 big screen (maximized of course) Otherwise so long as your CPU can handle you can open as many instances of revit as you like and put one on each monitor if you'd like.
Correct me if i'm wrong. As I said, I have no experience with revit and multi monitors.. just multi monitor outpout in general.
3 Posts No Rating |
It looks like one big screen, al you can do is minimize the program window and stretch it across. 4 monitors sounds like overkill ...
90 Posts No Rating |
You can use more monitors, stretch revit to fit all monitors and open many projects you can, arrange windows-views on that 'big' screen manualy. It is very usefull to have open more views of one project, floor plans and 3D ... or section in same time, or more diferent projects or open Revit in one monitor and other monitor is something else, Acad or browser or TV ...
3 Posts No Rating |
yes you can put different revit "views" on different monitor with the revit program open once. it is really handy having more real estate to work with. Good luck.
i had two monitors for awhile but went back to two..
got tired of turning my head back and forth..
i can alt tab from window to window easier then
turning my head.. and more than two would
really be no good..
opps
i had two monitors for awhile but went back to one..
i can alt-tab from window to window easier then
really be terrible.. if you think you need more
screen space just get a 21" monitor and set to
1152 by 864 and put your head back on the
head-rest and relax
of course everybody has a totally different
idea of everything if you know what i mean
26 Posts No Rating |
i'm thinking of getting a 27"
what are the pros and cons of one big one
or two medium sized ones?
two monitors? |
Wed, May 3, 2006 at 7:30:53 PM
Dual Monitors with 2011 |
Thu, Jul 15, 2010 at 1:44:28 PM
Multiple monitors |
Tue, Nov 20, 2007 at 8:53:21 PM
Using 2 monitors |
Tue, Jun 14, 2005 at 10:08:29 PM
Dual Monitors |
Sat, Feb 23, 2008 at 9:44:44 PM
