9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Wall Dimensioning changing after changing Wall Type.
Hello,
We've recently changed the way that we dimension and draw our walls, is there a simpler way to change all the walls. The issue is that our 70mm walls change to 90mm when I change the wall time, even though I have it hosting to the stud and not the plaster lining.
See attached image.
1. Current wall types in drawings
2. New dimensioning, dimensioned to stud not plaster lining.
3. What occurs when I select and change current wall types.
Is ther an easier way then redimensioning all the old projects.
Thanks
edit your walls so that the core face is the stud face , then dimension to core
Changing wall finishing thickness without having to align it again |
Tue, Jul 3, 2018 at 10:42:11 AM
Changing wall/wall tag parameter |
Thu, Oct 14, 2010 at 12:44:42 PM
Changing wall thickness issue |
Thu, Oct 12, 2006 at 11:07:14 AM
Changing wall types midmay through wall |
Mon, May 22, 2006 at 1:45:33 PM
Changing wall based family to non wall based? |
Wed, Nov 10, 2010 at 7:18:22 AM
