Forums >> Revit Structure >> Technical Support >> HELP!!! 500 x 1500 Tile with 6 mm gap in between
Tue, Aug 30, 2016 at 11:16:16 AM | HELP!!! 500 x 1500 Tile with 6 mm gap in between
shraddha158
Hello All!
I am trying to make a PAT file for a floor tile that is 500 x 1500mm with 6mm gaps between the tiles.
Can someone please help..spent a few hours trying to get it to be a perfect repeat square in CAD but just not getting there.
Is there a formula that can be used directly in Revit that will make this is quicker process ?
THANKSSS
shraddha
Tue, Aug 30, 2016 at 11:26:06 AM | HELP!!! 500 x 1500 Tile with 6 mm gap in between
Formula?
For simple rectangular pattern files, I typically find a pattern that is similar and edit the appropriate numbers.   In this case, I might use a 1/3 running bond brick or tile pattern that has the mortar joints.
If you are trying to draw it in Revit to use with hatchkit, then array is your answer.
Tue, Aug 30, 2016 at 10:00:56 PM | HELP!!! 500 x 1500 Tile with 6 mm gap in between
hugh
3.5 Stars: 4 Votes
There is no inbuilt formula ir Revit but HatchKit has a wizard for this
Looks like 1/3 overlap. Try this:
;        Written by HatchKit for Revit
;        HatchKit for Revit (c)1990-2016 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 31/08/2016
;-Time                                   : 12:35:02 PM
;-HatchKit Version                       : 3.1.8.2681
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*shraddah158,VERTICAL RUNNING 500mmx1500mm bond=1/3
;%TYPE=MODEL
90,0,0,502,-506,1500,-6
0,0,1500,506,502,500,-1018
-90,500,1500,502,-506,1500,-6
180,500,0,506,502,500,-1018
Hugh Adamson
www.hatchkit.com.au
Recommended build for a $1500-$2500 budget
Wed, Nov 5, 2008 at 11:03:49 PM
Chevrolet Silverado 1500 Z71
Mon, Feb 4, 2013 at 8:08:18 AM
Gap in Roof
Tue, Oct 4, 2005 at 1:33:08 AM
CREATING A GAP BETWEEN ELEVATION TAG AND WALL
Thu, Oct 22, 2009 at 1:40:39 PM
Distributed Rendering
Wed, Aug 12, 2009 at 1:16:53 PM
Page generation time: 0.0533
