Forums >> Revit Building >> Technical Support >> Generic model in section view
Thu, Aug 25, 2016 at 7:52:59 PM | Generic model in section view
clickster
clickster Avatar
I cut a section through my project. A generic model tht is outside the section view range is showing in the section. Does anyone have an idea why this would happen? The category of the family is 'specialty equipment'. Please help!
Fill what is empty. Empty what is full. Scratch what itches.
Fri, Aug 26, 2016 at 4:58:28 AM | Generic model in section view
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Clickster,
To confirm, the family that is causing the issue is a 'Generic Model'? Or is it a "Speciality Equipment'? Important difference as i think the issue you are encountering is to doing between what category of family are "cuttable" and "Non-Cuttable".
Basically, if any part of your Speciality Equipment is being cut by the section then it will not cut through it, it will actually show the entire family in the view.
Here is a link to Non-Cuttable Families.
Hope this helps.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Fri, Aug 26, 2016 at 2:00:29 PM | Generic model in section view
clickster
clickster Avatar
Thanks very much Shatner... yes, the category was specialty equipment. I changed it to another category, and now the section looks fine. Much appreciated.
Generic Model behind Section Cut.
Thu, Dec 3, 2015 at 7:16:19 AM
generic model family not cutting in section
Tue, Jan 11, 2011 at 7:14:50 AM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:18 PM
Generic Model Materials
Fri, Oct 3, 2014 at 1:53:40 PM
generic model cutting issue 2016
Sat, Aug 27, 2016 at 7:43:47 AM
Page generation time: 2.6897
