Forums >> Revit Building >> Technical Support >> Revit Hatching
Wed, Aug 24, 2016 at 12:46:09 PM | Revit Hatching
JHARevit
1 Stars: 1 Votes
I've been searching forums and have not found an adequate answer for my quandry:
I want to rotate some of the "Drafting" hatch patterns.  Anyone know the code for the *.pat file to do this?  I'm not interested in making them "model" patterns, as every forum I've read states, as I want them to scale along with the details.
As an example, pattern "Earth", in AutoCAD, is "standard" at a angle but our standard utilizes both angled and vertical/horizontal linework to differentiate topsoils vs. fills.
Wed, Aug 24, 2016 at 1:11:06 PM | Revit Hatching
I need to correct this thought "... I want them to scale along with the details...."   Drafting patterns never scale.   They are always the same scale relative to paper space and do not scale with the view scale.    So are you sure this is what you want?
To 'rotate' a drafting pattern, you would have to rewrite the pattern file.   This is not at easy task and taks someone really knowledgable or a program like hatchkit.
Making a drafting pattern a model pattern is a simple, one line of text alteration of the file.
Wed, Aug 24, 2016 at 1:40:45 PM | Revit Hatching
JHARevit
1 Stars: 1 Votes
Technically drafting patterns do "scale" as they remain the same printed optic regardless of drawing scale.  That is only accommodated by a changing scale based on the view scale.  Model patterns do not scale as they remain unchanged no matter the view scale.
So, yes I'm sure that I want the hatch pattern to remain the same printed size regardless of the detail or view scale presented.  This, to my knowledge, can only be accommodated with a "drafting" pattern.  The "easy" of the model hatch is what I keep reading, but I'm having trouble figuring out how one actually makes that work in application.  The hatch remains the same regardless of scale.  So on small scale details it prints black, and large it's normal.  Hardly functional at all.  Or do people create the same hatch mutiple times for various scales and then be presented with the tedious task of matching the hatch scales with the drawing scales?
It's really quite sad that such a powerful program can be so inept at the simplest of documentation tasks.  What project doesn't need detail hatching?  It's been required on every single Architectural detail I've seen or created in my 16 years now...
Wed, Aug 24, 2016 at 2:00:10 PM | Revit Hatching
It takes people awhile to understand how much better Revit's hatches are because of model hatches.
Revit has a built in solution for drafting patterns when used with model elements like walls.   That is described here in your HELP.  This works well with detail views where these model elements are shown.  Revit allows you to load multiple drafting and model patterns at different scales, you just have to give them unique names during the load.   To do this, the pat file needs to be by itself and not in the standard combination file.
You specifically asked about the 'earth' pattern.  I suggest you make this a model pattern to be able to rotate and you will only need a couple of sizes loaded.  I also have my plywood pattern as model based but it is basically one size only and I only use it in larger detail views.
Wed, Aug 24, 2016 at 2:14:07 PM | Revit Hatching
JHARevit
1 Stars: 1 Votes
Sorry about the multiple repeats.  Didn't realize the refresh button does it.
I fully understand the difference between drafting and model hatching.  Why they cannot be manipulated to any reasonable extent is baffling to me.  It's counterproductive and restrictive.  Again, the model hatching does not sound at all like my answer.  When the details contains the actual model, sure, but the details I'm creating do not.  They are "standards" and have no bearing on the physical model.  Hence the need for Drafting hatches.  And, as I previously stated, multiple versions of the same hatch is laughable at best.  It's complicating things far more than need be.  I guess it's just another reason Revit still hasn't proved to be truly better at Construction Document production work than AutoCAD.  Still just a rendering program.  I think I'll just be exporting the work I've done and finishing it in AutoCAD.  smh
Wed, Aug 24, 2016 at 2:46:46 PM | Revit Hatching
You still don't understand a very important point.  Model hatches do not have to be used in model elements.   They can be used in detail elements and even drafting views.  They are a very powerful tool if you learn to use them.   They can exist with any family as well as project.
New Revit users always have problems just like OLD people.   I know because I'm old and I used  Autocad for over 25 years (started w/ 2.1), then I learned Revit and now I know I can do it better and faster in Revit then I could ever do it in CAD - and that includes simply drafting.
Wed, Aug 24, 2016 at 3:22:06 PM | Revit Hatching
JHARevit
1 Stars: 1 Votes
Your very important point is irrelevant to my post's inquiry.  So I've attached a screen shot to clarify my intent.  All boxes are 3'-0" square.
There are instances where we want the hatching to remain consistent (in the printed state) regardless of drawing scale.  Is that not the definition of a "drafting" pattern?  As you can see the Model Hatch fails miserably and is therefore completely unusable for the purposes of this post's inquiry.  I made that clear in my first response.  But, I'm guessing this is where you tell me I don't understand, am old, or some other troll-like insult and that the best way is that I'll have to create multiple versions of the same hatch to accommodate the various scales and orientations.  To that I say Revit-0, AutoCAD-1...
Wed, Aug 24, 2016 at 3:23:36 PM | Revit Hatching
JHARevit
1 Stars: 1 Votes
It would help if the attachment was correct...so here it is
Wed, Aug 24, 2016 at 3:31:07 PM | Revit Hatching
I fully understand your images but I don't have those problems because I will use the correct hatch for the application.  I've tried to help you understand Revit in regards to what you want.  I'm sorry that you are having problems here, perhaps you just need to stay with CAD.
Wed, Aug 24, 2016 at 3:38:26 PM | Revit Hatching
JHARevit
1 Stars: 1 Votes
Based on your responses you don't have that problem because you, or your firm, has already spent countless hours developing multiple copies of model hatching to accommodate all scales, views, etc..  I'm not interested in wasting my time making up for the failure of the Autodesk programmers.  I'll continue my hybrid approach utilizing the best parts of both programs.  Maybe someday Autodesk will realize how dumb it all is and make a truly well-thought, intelligent and intuitive program.
That said, delete this post.  It doesn't seem to contain much useful information anyways.
Wed, Aug 24, 2016 at 3:51:21 PM | Revit Hatching
#11
sllana
5 Stars: 2 Votes
Use the "soil" pattern of autocad adding ";%TYPE=DRAFTING" under the name of the hatch in the descrition
Thu, Aug 25, 2016 at 10:49:52 AM | Revit Hatching
#12
hugh
3.5 Stars: 4 Votes
Yoou might find the fill rescaling and rotation capability provided within our free HatchKit Add-In for Revit  handy to create a rescaled pattern on the fly without having to reload from a .PAT file.
You can obtain the add-in from the Revit Exchange or from our website.
Hugh Adamson
www.hatchkit.com.au
Topography and hatching in section / elevation
Sat, Sep 27, 2008 at 7:55:41 PM
Topography Hatching
Tue, Feb 28, 2012 at 8:15:31 AM
HATCHING 2008
Fri, Jun 22, 2007 at 11:19:07 AM
Area Plan Hatching
Fri, Oct 26, 2018 at 10:23:00 AM
Changing line weights to hatching?
Wed, Apr 26, 2006 at 10:44:00 PM
Page generation time: 4.5846
