Forums >> Revit Building >> Technical Support >> converting files
Tue, Aug 23, 2016 at 5:16:34 PM | converting files
integrity
How to convert rte files to pdf.
Tue, Aug 23, 2016 at 7:26:44 PM | converting files
You don't convert to PDF, a PDF is an image file.  You print to PDF using a print driver assigned in the Revit print process.
Wed, Aug 24, 2016 at 7:55:42 AM | converting files
integrity
I can print the drawings with my computer. No problem. However, I need to email the files to the customer
and he can only print from a pdf file.
Carl
Wed, Aug 24, 2016 at 9:24:28 AM | converting files
Please re-read my answer.
Wed, Aug 24, 2016 at 9:55:18 AM | converting files
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Integrity,
As Hub said, you need print your drawings using a .pdf plotter.
This is the one we use in our office.
http://www.cutepdf.com/
Kind Regards,Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Converting Revit files to AutoCAD files
Wed, Sep 15, 2010 at 2:09:17 PM
Converting .skp files to .rfa?
Fri, Jun 25, 2010 at 3:05:23 AM
converting files for use between cad programs
Thu, Apr 30, 2009 at 12:39:03 AM
converting files
Tue, Sep 25, 2007 at 12:48:14 PM
Converting "Solidworks" files to Revit (or Autocad) format
Fri, Mar 20, 2015 at 7:36:17 AM
Page generation time: 0.1973
