Forums >> Revit Building >> Technical Support >> Creating Revit Families From DWG Blocks
Sun, Aug 21, 2016 at 8:02:55 AM | Creating Revit Families From DWG Blocks
Ipauline
I'm currently working to capture a proposed new office configuration. The furniture vendor Trans America provided the CAD block in which I coverted into a Revit Family. When placing the RFA in plan view it comes over in a 3D orientation and not flattened to complete the placement. I have also tried to place in a 3D view, but the RFA is very unstable. This furniture type is unavavailable on the Revit or sketup platforms. Are there any tips on how I can redo the the CAD-Revit conversion?
The RFA is attached here for analysis.
Thanks,
Ivan Pauline
Mon, Aug 22, 2016 at 3:17:09 AM | Creating Revit Families From DWG Blocks
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Ivan,
How did you insert this? See image, but if it doesn't look correct in the Revit Family enviroment then next guranteed it won't look right in the project enviroment. Which template file did you use?
Must of the time, i find that CAD files are large, ugly and unenjoyable to use. Revit modelling might be more time consuming but its worth it in the long run imo. Something to consider. Smile
Anyway, see attached .rfa. Hopefully this will work better for you.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Importing DWG with clipped blocks
Mon, Sep 17, 2012 at 12:00:44 PM
AutoCAD DWG Blocks
Sun, May 9, 2010 at 10:43:13 AM
dwg 3D blocks
Wed, Dec 3, 2003 at 6:37:53 PM
editing families when creating new
Fri, Sep 9, 2005 at 3:17:20 PM
Page generation time: 7.4724
