Forums >> Revit Building >> Technical Support >> Seperating steel frame ( NEED HELP)
Mon, Aug 15, 2016 at 8:27:05 AM | Seperating steel frame ( NEED HELP)
duduvuive
Hi all,
Im finding the way to make this panel through mesh system ( but i couldnt find out) Sad
Basically, Its a hanging frame just for seperating the space for restaurant. If anyone can create or help ,I greatly appreciate your help.
Thank you!.Smile
Mon, Aug 15, 2016 at 8:39:48 AM | Seperating steel frame ( NEED HELP)
marmiketin1
4.5 Stars: 10 Votes
you should use a curtain wall system with a transparent panel that has a crosshatch surface pattern to represent the mesh
Mon, Aug 15, 2016 at 9:36:37 AM | Seperating steel frame ( NEED HELP)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is basically a chain link fence, there are families here you can download and modify to your needs.
Mon, Aug 15, 2016 at 10:38:37 AM | Seperating steel frame ( NEED HELP)
marmiketin1
4.5 Stars: 10 Votes
Made a curtain panel system for yout with a custom panel that looks like the image. It is in the project so just open the project and copy past it into your project so you get all the families imported in. There are both type and instance parameters associated with the system.
Edited on: Mon, Aug 15, 2016 at 10:40:03 AM
UK - looking for a parametric steel portal frame for a factory unit!
Tue, Apr 19, 2005 at 11:06:43 AM
Warehouse Structure
Sun, Oct 15, 2017 at 3:04:55 AM
flat steel frame
Thu, Oct 1, 2009 at 3:46:39 PM
True plan view of sloped steel?
Mon, Feb 27, 2017 at 9:31:22 AM
14
Help - Custom Steel Frame - Revit 2016
Tue, May 26, 2015 at 8:44:05 AM
Page generation time: 0.5180
