Forums >> Revit Building >> Technical Support >> Window and Door OverView Sheet
Wed, Apr 12, 2006 at 7:10:49 AM | Window and Door OverView Sheet
elvis
Hi All,
while building an parametric window family I am wondering how to create an window/door overview sheet [out off the design project] with all the used windows/doors including front sight, a horizontal and a vertical section of each window mark
including a supporting text that puts all the parameter values ,as defined, in a text block.
like: windowframe sizes, heght, width, etc.
what is the best way, will callouts work for this?
kind regards,
E
note: all the windows are tagged with a mark.
Thu, Apr 13, 2006 at 8:07:53 AM | RE: Window and Door OverView Sheet
elvis
is there no one who needed to create a window overview? do you create window drawings as callouts and add sections, which will be many ofcourse or do you create the drawings from the family files. I suppose that the window schedule needsto be supported by window drawings? how to?
Thu, Apr 13, 2006 at 12:07:06 PM | RE: Window and Door OverView Sheet
wcrane
Well, so, legends allow you to create a visual palette or key legend of the components in a project. The objects in a legend cannot be tagged and they are not calculated on the schedule. they can be pre-created and put into your templates. You cant show windows in section but thats what wall sections are for right? you can use detail components an lines to create a 2d section of the windows. I dont think legends will do all you want but most of it anyway.
Sun, Apr 16, 2006 at 8:40:04 AM | RE: Window and Door OverView Sheet
latemore
latemore Avatar
3 Stars: 2 Votes
hi elvis there have been a few threads on legends - do a search maybe. legends are wonderful. to get the rest of your needs, just create a standard schedule, and put it near the legend. we add text titles below each legend item that match the schedule, and that's about it!
Sun, Apr 16, 2006 at 8:51:46 AM | RE: Window and Door OverView Sheet
coreed
coreed Avatar
4 Stars: 16 Votes
here is a miniclip from DGCAD on legends Right Click and Save Target As... http://www.dgcad.com/downloads/REVIT_8_39_LEGENDS2.wmv
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
door & window elevation sheet
Tue, May 30, 2006 at 12:39:19 PM
Transfering door and window tags to Sheet File
Tue, May 8, 2007 at 2:13:35 AM
Door/Window schedules
Tue, Oct 11, 2005 at 12:40:25 AM
window and door schedules
Wed, Feb 4, 2004 at 7:02:49 AM
Big model => Overview sheet / detail sheets
Tue, Aug 25, 2009 at 7:54:19 AM
Page generation time: 0.4717
