Forums >> Revit Building >> Technical Support >> intellegent room tagging
Fri, Aug 5, 2016 at 4:29:13 AM | intellegent room tagging
Mandar1886
team,
i am trying to prepare an intelligent room tag which will export schedule by default it creaes easily the room name,area,etc,but i want to add a parameter which will give us the room name s "parking requirement" as in to add a formula which will say its 2 cars per room/shop and further.
can we add formulas to a paramter which we can add.???
Fri, Aug 5, 2016 at 9:26:01 AM | intellegent room tagging
Read this in your HELP.
create a field whose value is calculated from a formula click (Calculated Parameter). Enter a name for the field, set its type, and enter the formula for it using existing fields in the schedule.
For example, if you want to calculate an occupancy load based on the area of a room, you could add a custom field called Occupancy Load that is calculated from the Area field. Formulas support the same mathematical functions as in the Family Editor.
Room tagging open rooms
Wed, Feb 9, 2011 at 7:04:16 AM
Room Tags - Tagging Multiple Rooms as One
Tue, Feb 19, 2008 at 1:25:28 PM
Room Tagging
Sun, Jul 23, 2006 at 4:42:24 PM
Ceiling Height Tagging
Tue, May 9, 2006 at 9:49:14 AM
Tagging 2 rooms with the same tag/area
Wed, Nov 20, 2013 at 8:11:44 PM
Page generation time: 0.1307
