Forums >> Revit Building >> Technical Support >> "can't find solutions for formulas" error
Wed, Aug 3, 2016 at 3:47:53 PM | "can't find solutions for formulas" error
sfountain
this error mesage popped up today when attempting to duplicate a door type,a nd i havent been able to figure it out of
find much info on it. Im using R2017, and I just updated it yesterday - SP2 i believe. This is only occurring in this file
thus far. The file uses a custom template. While i cant duplicate a door type, I am able to create a new type.
the doors are all custom created, and have had no issues in the past. Ive tried reloading them, and ive even tried
deleting the two formulas I had in the door famillies and then reloading them - no dice. the formulas are pretty simple -
calculating clear width and the number of persons. Any thoughts on what might be causing this? TIA
Edited on: Wed, Aug 3, 2016 at 4:11:10 PM
Wed, Aug 3, 2016 at 4:42:36 PM | "can't find solutions for formulas" error
Bartholomew
5 Stars: 2 Votes
Check out PIJPIWO's post on the "Suddenly Can't Insert Window In Project..." thread started earlier today. I think it's applicable towards resolving your issue.
Wed, Aug 3, 2016 at 5:46:21 PM | "can't find solutions for formulas" error
sfountain
I took a look at the thread, and that prompted me to go in and look for a constraining issue, as some of the door families
have constraints for door swings, but not all of them do.
Also, this problem is a bit different - I have no trouble placing new instances of any of the doors - I can move them, flip
them, change parameter values, etc. - all working like they should. I just cant duplicate an existing door type - I can,
however, create new types in the project.
I read elsewhere of a smiliar thing happening when someone updated revit, and the problem appeared to be an
issue with a custom project template, so I was wondering if that might be the culprit.
"Constraints are not satisfied"
Wed, Jun 7, 2006 at 8:17:24 AM
Error Message: "Circular Chain of Reference" - help requested!
Thu, Nov 24, 2011 at 9:34:08 PM
Error message
Fri, Feb 22, 2008 at 12:58:30 AM
What's up with the tezt "size"????? [ 1 2 ]
Tue, Aug 19, 2008 at 10:16:25 AM
25
A Serious Error [ 1 2 ]
Thu, Jul 26, 2007 at 11:41:07 AM
21
Page generation time: 4.8432
