27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> create a wall sweep on an angled wall (gable end wall) (2017)
I was wondering how to create a wall sweep on a gable-end wall? I would like to show a trim board at the top of the gable-end wall that follows the angle at the top of the wall. when I try to use the wall sweep tool it seems to only let me move in the vertical or horizontal direction.
Wall sweeps are either vertical or horizontal - nothing else. An in-place sweep will work but it will not be correct at the corners.
so at the corners can I use a void form to cut the portion of the sweep that I dont want to see? if so what would be the best void form to use in this situation?
Does it matter? Any void you create (in-place) will work becuse you will set it to cut your sweep and will not cut anything else.
BTW - Not saying this is a good solution but a thin wall sketched to the same you need will also work as well as an in-place extrusion sketch to the shape.
you could use use a roof fascia with a negative horizontal profile offset the distance of the overhang. Just a thought.
Edited on: Wed, Aug 3, 2016 at 2:46:58 PM
Angled Wall Sweep End |
Thu, May 7, 2009 at 10:56:28 AM
Gable End Wall |
Tue, Mar 20, 2007 at 11:48:35 AM
Newbie: Attach wall to roof gable end: Strange Rendering |
Mon, Jun 1, 2009 at 4:28:53 AM
REVIT 2013 - Angled Layered Wall Ends |
Tue, Dec 3, 2013 at 8:18:33 AM
Could not create integral wall sweep for wall instance...... |
Wed, Oct 2, 2013 at 1:21:10 PM
