Forums >> Revit Building >> Technical Support >> if(not(and
Wed, Aug 3, 2016 at 10:40:37 AM | if(not(and
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
I need an example for if(not(and conditional statment,  Nested   GV is the checkbox, GW is the dimension parameter
this does not work:    if(not(and(G1V, G2V), (G1W - G2W), (G1W + G2W)))
and I am playing with this:  If a checkbox is not checked I need to do somethng.
if(and(G1V, G2V, G3V), (G1W + G2W + G3W), if(and(G1V, G2V), (G1W + G2W), if(and(G1V, G3V), (G1W + G3W), if(and(G1V, G4V), (G1W), (G1W)))))
Thanks
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Wed, Aug 3, 2016 at 3:59:33 PM | if(not(and
Bartholomew
5 Stars: 2 Votes
wouldn't the formula start: if(and(not(G1V),not(G2V)),...
Wed, Aug 3, 2016 at 6:13:36 PM | if(not(and
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Hi Bartholomew, I have seen and example using "or" that looks the same as the example you show, but where is your second "and" parameter, I only see one.
I finaly got mine working but mine does not meet your example on the NOT part and this may be suspect to why it was querky. but it does what I want so I am now content.
if(and(G1V, G2V, G3V), (G1W + G2W + G3W), if(and(G2V, G3V, G4V), (G1W + G2W + G3W),if(and(G1V, G2V), (G1W + G2W), if(and(G1V, G3V), (G1W + G3W), if(and(G1V, G4V), (G1W), if(and(G2V, G4V), (G1W + G2W),if(and(G3V, G4V), (G1W + G3W),  if(not(G1V),(G1W + G2W + G3W),(G1W)))))))))
Any techniques to shortent this?
Wed, Aug 3, 2016 at 7:07:12 PM | if(not(and
Bartholomew
5 Stars: 2 Votes
You're talking about a different conditions to evaluate. I provided the correct way to write an "if(and" evaluation.
An "if(and" returns "true" if both statements are true.
An "if(or" returns "true" if only one condition is true; not both.
There is no "if(not" the way you were using it. G1V is either ON (G1V) or OFF (not(G1V)). G2V is either ON (G2V) or OFF (not(G2V)).
Therefore: if(and(not(G1V), not(G2V), "true", "false"). Both G1V and G2V must be OFF to return "true".
if(or(not(G1V), not(G2V), "true", "false"). Either G1V or G2V must be OFF to return "true".
edit: I'm curiouis: "if(and(G1V, G2V, G3V), "true", "false")...Does this formula really work for you? How are are able to have 3 conditions to evaluate?
Edited on: Wed, Aug 3, 2016 at 7:20:19 PM
Edited on: Wed, Aug 3, 2016 at 8:03:25 PM
Wed, Aug 3, 2016 at 9:24:57 PM | if(not(and
Bartholomew
5 Stars: 2 Votes
cadman: very cool. Just got back to test. 3 Y/N conditions were indeed evaluated. Learn something new everyday. Thanks for sharing. Cheers!
Thu, Aug 4, 2016 at 6:38:02 AM | if(not(and
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
I removed my NOT and it still works as I need.  this is a 4 visibility parameter formula, I am working my way to 6.
Take a look at the family, load it into a new file and hide 5 & 6 because they are not functional yet,  You can change the size of the box and each piece will move accordingly and turn on and off as specified.  the size is a type parameter the visibility is an instant parameter.  in the new file, go to 3D so you can see the numbers on each box, apply shade for color, let me know what you think and if you know of a way to simplify the formulas, please share.
Thanks
Edited on: Thu, Aug 4, 2016 at 7:10:53 AM
Page generation time: 1.3580
