Forums >> Revit Building >> Technical Support >> Grid Partial Visibility
Wed, Aug 3, 2016 at 10:22:18 AM | Grid Partial Visibility
AmyEAmyW
Attached some images to reference because this is a bit tricky to explain, but the grid lines in our project are visible in our views, however the grid lines are appearing as if a large section of them are masked. When the grid lines are selected, its apparent that the extent of the grid line is what it is intended to be, but when deselected, only the bottom and top of the grid line are showing.
Its happening in all of our views, and it isn't a computer graphic error because they print like this as well. And the grid lines had been behaving normally until this week. I'm stumped.
Has anyone had this problem or can offer a solution?
Thanks in advance,
Amy
146625_Extent_of_grid_when_selected_-_section.png146625_Extent_of_grid_when_selected.png146625_Grid_partially_visible_-_section.png146625_Grid_partially_visible.png
Wed, Aug 3, 2016 at 12:58:46 PM | Grid Partial Visibility
Read this in your HELP, the answer is there.
Wed, Aug 3, 2016 at 1:08:39 PM | Grid Partial Visibility
AmyEAmyW
Wow I feel silly now! Thank you so much! Someone must have changed this without realizing. I hadn't known about these properties!
Datum Extent Visibility
Mon, Nov 12, 2007 at 3:28:18 PM
column grid visibility
Wed, Nov 15, 2006 at 3:43:13 PM
Partial Ceiling Grid Demolition HELP!!!
Fri, Feb 1, 2008 at 11:47:44 AM
Partial Element Visibility
Thu, Sep 3, 2015 at 1:02:29 AM
GRID AND SECTION VISIBILITY
Thu, Dec 20, 2007 at 8:03:27 PM
Page generation time: 1.9894
