Forums >> Revit Building >> Tips & Tricks >> Changing Light color in REVIT
Tue, Aug 2, 2016 at 4:53:52 PM | Changing Light color in REVIT
josjeffe
does anyone know how to change the color of the lights in revit to red blue or green?
Tue, Aug 2, 2016 at 5:34:16 PM | Changing Light color in REVIT
Process is described in your HELP....Best first source for questions.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-E419C94B-AE14-42EB-B4F6-456111784E98
Wed, Aug 3, 2016 at 9:02:00 AM | Changing Light color in REVIT
josjeffe
This parameter is not an option when the family is created by a manufacturer. In some fixtures from the manufacturer there is the option for color filters or intial color output.
Wed, Aug 3, 2016 at 9:30:50 AM | Changing Light color in REVIT
marmiketin1
4.5 Stars: 10 Votes
If the parameters for the light are not visible then maybe its because the actual light source is nested into the fixture family. Click on the light source and click edit type in properties.
However if a manufacturer has set it up so that the light source parameters cannot be changed it is probably because how it is setup is the accurate representation of the product and the options available for it.
Wed, Aug 3, 2016 at 9:38:41 AM | Changing Light color in REVIT
josjeffe
Big help thank all!   This luminaire is a RGBW and has the ability to change colors, I understand the manufacturer has set the parameters to keep accuracy, but if I duplicate the family and make my modification there I could keep them separate. How would I add a color filter to show the RGB options?
Mon, Aug 8, 2016 at 12:56:58 AM | Changing Light color in REVIT
Rickardo
Thanks for sharing this tip.
Sun, Aug 21, 2016 at 10:53:57 AM | Changing Light color in REVIT
cityman
 In some fixtures  there is the option for color filters or intial color output.
Mon, Aug 22, 2016 at 10:43:22 AM | Changing Light color in REVIT
josjeffe
Since the fixture does not have the color filter option, could I add this to the family?
Mon, Aug 22, 2016 at 12:42:56 PM | Changing Light color in REVIT
marmiketin1
4.5 Stars: 10 Votes
I made a light source family you can insert into you light fixture family. It has a parameter to control the material. You can change the lighting properties in the light source family itself.
Edited on: Mon, Aug 22, 2016 at 12:51:17 PM
Fri, Aug 26, 2016 at 4:32:25 PM | Changing Light color in REVIT
josjeffe
Hey thanks
CHanging color of walls/roofs
Tue, Oct 31, 2006 at 8:54:31 AM
Light color
Mon, Jul 25, 2005 at 7:02:27 PM
Lighting Color
Sat, Apr 16, 2011 at 9:43:08 PM
Building changing color...because of shade of grcurseused. Ever happen to you?
Sun, Apr 10, 2005 at 10:02:43 PM
Color of lighting after rendering
Wed, Mar 26, 2014 at 8:21:12 AM
Page generation time: 5.1441
