Forums >> Workflow & Implementation >> API & Third Party Apps >> Need help with Macro program for point cloud visibility
Mon, Aug 1, 2016 at 9:22:14 AM | Need help with Macro program for point cloud visibility
Dan5022
Hey everyone.  This is my first post, I am new to Revit City. I was hoping I could get someone to help me with a problem.
I am ultimatly trying to create a button or shortcut key to turn point cloud visibility on/off, thats it.  I have been playing around with the Macro creator, and have had zero luck figuring it out. I am not a programer, so its basicaly greek to me...
I have tried doing google searches for help, but everything I find assumes you are a programmer so again, it doesn't make sense to me.
I've also tried doing searches for something already written but haven't had an luck there either.
Is there anyone out there that can please write some code to help me do this?
Thanks a bunch!
Wed, Sep 28, 2016 at 6:13:49 AM | Need help with Macro program for point cloud visibility
SeanWithe
Sorry I can't help but I'm ahving the exact same issue, don't understand why Revit wants to make things difficult at every possible occasion. Even cant attach a keyboard shortcut to edit your View Range. Hopefully someone see's this thread soon!
Sun, Oct 9, 2016 at 12:17:15 AM | Need help with Macro program for point cloud visibility
revdev
I have dealt very little with point clouds. That being said, if you are trying to create a one button click to hide them in a view then try the following:
public void HidePointCloud()
     var doc = this.ActiveUIDocument.Document;
     var view = this.ActiveUIDocument.ActiveView;
     FilteredElementCollector pointCloudCollector new FilteredElementCollector(doc, view.Id).OfClass(typeof(PointCloudInstance));
     var pointCloudElements = pointCloudCollector.ToElementIds();
       if Crying pointCloudElements.Count > ) view.HideElements(elements);
edit: replace the stupid smiley with a "("
Edited on: Sun, Oct 9, 2016 at 12:20:25 AM
Thu, Oct 13, 2016 at 5:26:51 AM | Need help with Macro program for point cloud visibility
SeanWithe
Hi RevDev
I'm hopeless with code and don't know where I am meant to copy that text to. I know how to create a new module and macro but when I get to actually writing the command I have no idea what I'm looking at.
Hopefully Dan is still getting updates for this thread as this could save so much time.
Thu, Oct 13, 2016 at 8:31:48 AM | Need help with Macro program for point cloud visibility
revdev
If you already have a c# macro set up just paste the code into the macro below the line that says "revit macro generated code" and then press f8 to build the new macro. You shouldn't get any errors and after that click the macro manager, press the plus sign next to the name of your macro and click on the remove point cloud module in the view you want to hide the point clouds. Then click run.
If you need more help, just let me know.
Thu, Oct 13, 2016 at 1:44:23 PM | Need help with Macro program for point cloud visibility
revdev
(double post)
Edited on: Thu, Oct 13, 2016 at 1:45:39 PM
Tue, Apr 25, 2017 at 4:07:38 PM | Need help with Macro program for point cloud visibility
surfingjp
if you have a progrmable keypad, keyboard or mouse this should work.
VG, Shift Tab, >, >, >, >, >, Tab, Tab, Tab, Tab, Tab, Space, Tab, Enter
The number of > depends on Local or Central Model
Revit 2014 Point Cloud Benefits/limitations?
Fri, May 24, 2013 at 8:00:13 AM
Point Cloud in Revit 2014 no longer working in Revit 2015
Fri, May 15, 2015 at 3:23:06 AM
Revit 2014 Point Cloud Plot Issue
Fri, Apr 25, 2014 at 8:44:48 AM
Point Cloud location
Tue, Apr 8, 2014 at 2:23:56 PM
Export the Point cloud file to Auto CAD with Revit
Wed, Apr 2, 2014 at 4:38:32 PM
Page generation time: 0.8195
