Forums >> General Discussion >> Revit Project Management >> Spot elevations
Thu, Jul 28, 2016 at 10:04:16 PM | Spot elevations
alkin
Hi all!Have a CAD file with spot elevations written in text. Is there any way I can make this into a 3D landscape?Thanks!
Fri, Jul 29, 2016 at 8:01:28 AM | Spot elevations
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Check to see if the CAD file has points at each text location. If it does, check to see if the points are modelled in CAD in 3D ( i.e. each one's height is a differing Z height. If so then you can use them by importing the CAD file and creating a toposurface from or by creating a csv point file and creating the toposurface from that.If you only have text, then your only choice is to import the CAD file and over it create a toposurface using point levels that match the text numbering. It takes a bit longer but it won't kill you.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:54 PM
13
Spot elevations off by 1/4" ?
Wed, Aug 11, 2010 at 4:41:55 PM
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:14 PM
Page generation time: 2.2836
