Forums >> Revit Structure >> Technical Support >> Structural floor transparency
Fri, Jul 22, 2016 at 2:24:27 PM | Structural floor transparency
mark7321
I'm using Revit 2015. My view range cut elevation is +1'-0" above the floor I'm framing. Why do I need to make my structural floor 100% transparent to make the beams below it that are supporting it show up???? When I take the transparency away the beams don't appear. When I apply the transparency the framing appears. However, the walls below the slab that I would like to see in a hidden linetype are now in a solid linetype due to the transparency. I don't remember ever having this problem before.
Wed, Jul 27, 2016 at 1:28:48 PM | Structural floor transparency
marmiketin1
4.5 Stars: 10 Votes
Usually partition walls do not extend into the structural framing but rather stop 6" or so above finished ceiling unless they are bearing walls or are creating a fire seperation. If I were to guess you have your walls below extending up to the current level which is why you see them as your view depth for the floor plan extends dow past the top height of the walls.
RAC 2010 Structural Floor V Floor - Whats the difference
Tue, Jul 27, 2010 at 8:35:33 AM
Revit 2013 floor transparency
Wed, Jun 19, 2013 at 2:20:25 PM
Turn Off Transparency of Everything?
Thu, Feb 21, 2013 at 1:08:10 PM
Different between Structural Floor and Floor
Fri, Dec 10, 2010 at 4:47:12 AM
Glass Structural Floor...PLEASE HELP ME
Mon, Mar 24, 2025 at 12:35:48 AM
Page generation time: 0.3126
