Forums >> Revit Building >> Technical Support >> Project Address Label
Fri, Jul 22, 2016 at 9:56:48 AM | Project Address Label
UrbanDesign69
Hopefully this is really simple and I'm just overlooking or overthinking it.  I have a text parameter for Project Address in my title block and I'd like to add it to my Title Sheet where I list the legal info of the property.  I'm building a template for future projects and I want is to enter the Address in the Project Information on the manage tab and have it appear in the 1st column of the Title Sheet and on the Title Block for all sheets.
Fri, Jul 22, 2016 at 10:18:20 AM | Project Address Label
marmiketin1
4.5 Stars: 10 Votes
This should be done through shared parameters which is not the simplest of things to do and you should consult with your office before changing or adding shared parameters to the Office .txt file which houses this information.
Fri, Jul 22, 2016 at 5:39:56 PM | Project Address Label
UrbanDesign69
There's no office.  Just my laptop.
Mon, Jul 25, 2016 at 7:31:25 AM | Project Address Label
marmiketin1
4.5 Stars: 10 Votes
Heres the help link for shared parameter creation. I would suggest reading through this and the associated sections. This section is the same for almost all recent revit versions.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-94EA2B8E-2C00-4D29-8D5A-C7C6664DE9CE
Thu, Feb 8, 2018 at 1:37:25 AM | Project Address Label
UrbanDesign69
I don't want to create a new shared parameter, I want to create an embedded label to toggle visibility, and uses a link to the project info.  New post started (my apologies)
Cannot Edit Label After Inserting into Project
Fri, Sep 14, 2012 at 7:07:14 PM
please help with my title block
Sun, Aug 29, 2010 at 7:57:05 PM
Project Address Parameters for Title Sheet
Thu, Mar 23, 2006 at 5:01:01 PM
Address Lable
Wed, Feb 22, 2006 at 11:30:07 AM
Titleblock Label
Mon, Nov 21, 2005 at 1:06:02 PM
Page generation time: 2.9323
