Forums >> Revit Building >> Technical Support >> file size BLOATI
Thu, Jul 14, 2016 at 10:07:03 AM | file size BLOAT
iamian33
iamian33 Avatar
Greetings.   (R2015)
I am seeing an increase in file sizes for no known reason.The issue came to light while I am updating our door library. I noticed that my file sizes were 1.5mb to 2.4mb ... extremely large for a family, in my opinion.
I then opened a door family and purged unused ... 3 nested families were purged. When I saved the family, the size grew +/-250kb. I took another family and renamed one of the types, saved and the file size again grew. I've had some families double in size.
I have tested this in my 2016 install, same thing.I have tested this on a clean 2015 install on a different workstation, same thing.
I recall that AutoCAD had a similar corruption with file sizes increasing 10 or 30 times in size. The DGNPurge cleaned this up. Is there a similar known corruption with Revit? Is there a fix?? I need 1, please.
Edited on: Thu, Jul 14, 2016 at 10:09:23 AM
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, Jul 14, 2016 at 10:28:28 AM | file size BLOATI
I have seen file sizes grow if you only do a save.  But a save as creates a new file that is typically the most compact.   This is especially true with projects.
Thu, Jul 14, 2016 at 3:59:04 PM | file size BLOATI
iamian33
iamian33 Avatar
Thanks WW.
I've often used the SaveAs method to successfully compact projects but this has no affect on the file size for my families.  I have submitted a support request with Autodesk.  Hopefully they might offer something for this bloat.
Ian
Ian Shafer
File size
Fri, Nov 16, 2007 at 2:43:48 PM
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:42 PM
decrease file size
Tue, Nov 16, 2010 at 2:06:43 PM
Saved File Size
Mon, Feb 15, 2010 at 6:17:13 AM
DWF File Size
Fri, Oct 26, 2007 at 9:52:18 AM
Page generation time: 0.6766
