Forums >> Revit Building >> Technical Support >> Revit 2017 In Place Mass
Tue, Jul 12, 2016 at 1:31:14 PM | Revit 2017 In Place Mass
HermanMunster
I have been working with an inplace mass imported from Sketchup converted to .dwg in our latest Revit project. This works well for the design as we are in SD alongside of our CD. The issue is two fold when the mass has been revised and we reload the link in Revit.
The mass does update with any revisions however.....
The reloaded mass will not allow for apply curtain wall system to new face. The option is Greyed out. The other is we remove the existing curtain system and it will not allow the mass to be selected with a new curtain wall system.
The only workaround I have found is to delete the mass and reload. Then I can apply a curtain system. Any ideas
Tue, Jul 12, 2016 at 1:41:52 PM | Revit 2017 In Place Mass
HermanMunster
Apply curtain wall system to new face correction Model By face_Update to Face is greyed out
Tue, Jul 12, 2016 at 3:06:48 PM | Revit 2017 In Place Mass
HermanMunster
I have scrapped the idea of using an exported 3D dwg from skp file and just brought in the skp file. The dwg file is a polymesh which does not read in Revit. We were having issues with a direct skp insert which is why we went this route.
Changed the version opf the skp file to an earlier one and the import worked. In place mass floor work with an skp mass model.
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
No top surface for in place mass
Tue, Feb 19, 2013 at 9:55:33 AM
In-Place Mass Wirefram
Fri, Jan 11, 2013 at 8:47:32 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
what's an in-place mass?
Thu, Jan 14, 2010 at 12:52:09 PM
Page generation time: 1.5961
