Forums >> Revit Structure >> Technical Support >> masking regions overlap other views in sheet?
Wed, Jul 6, 2016 at 6:07:12 AM | masking regions overlap other views in sheet?
gregroberson
gregroberson Avatar
Hey everyone, I unfortunately have many coordination drawings that were made in autocad and are being requested to be on the Revit draings.  I was hoping to link the .dwg file becasue they will continue to be used for coordination.  I plan on not placing them in the "model" and simply drawting views.
I recall a post years back about how to mask unwasted regions with essentially a masking region that has a whole in in.  So I made my drafting views and linked in my cad files (the cad file is a true model space which has many views and paperspace layout tabs and I was hoping to continue with this) and applied the masking region, which is quite large.
However, when I place my revit drafting views onto sheets, the masking region from one view is masking the elements in other views which I was not anticipating.  Does anyone have a solution for this (if I was clear enough) or a bettter way of getting this task done.
Any thoughts are appreciated.
Greg
Wed, Jul 6, 2016 at 6:57:13 AM | masking regions overlap other views in sheet?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Any view on a sheet has priority by the order they were placed.  For example, if you put VIEW 1 on a sheet first then VIEW 2, VIEW 2 will sit over or mask VIEW 1.  Now if you add a VIEW 3, VIEW 3 will mask VIEW 1 and VIEW 2.
Thu, Jul 7, 2016 at 11:14:07 AM | masking regions overlap other views in sheet?
gregroberson
gregroberson Avatar
Thanks for the reply.  I figured that was happening.  I just wondered if there was a way to prevent masking regions within views from masking other vierw elements or if there was a better way to crop drafting views.
Can I have an AutoCAD layout tab linked inside a drafting view?
G
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:27 AM
11
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:22 PM
Mysterious masking regions showing up on plot
Wed, Sep 17, 2014 at 10:31:28 AM
Masking region appear grey in consistent color views
Wed, Feb 15, 2012 at 2:49:06 PM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Page generation time: 2.6884
