Forums >> Revit Building >> Technical Support >> Wall Based Railing
Tue, Jul 5, 2016 at 5:17:29 AM | Wall Based Railing
jamesm2505
I am trying to create a wall railing using the 'pipe-wall_mount' family, however when i set my hand clearance to its required value (100mm), the railing appears inside the wall, with the supports facing inward. This happens regardless of wether i set the position to left or right (or both).
How do I fix this?
Revit 2016
Tue, Jul 5, 2016 at 10:03:36 AM | Wall Based Railing
Railing location is defined by the railing sketch in plan view.
I don't understand how or what your 'pipe-wall_mount' family is.  Revit provides some stock railing mounts you can use within the railing process and you can create your own but they are not a wall based family.  They are railing based.
Tue, Jul 5, 2016 at 10:42:23 AM | Wall Based Railing
jamesm2505
Its a system family as far as I'm aware, as I've never had a need to download or use something like that before. It's still railing sketch based, but the sketch line follows the wall and the handrail is offset by a clearance parameter (which is the part which wasn't working) with the mounts being on the wall (ie along the sketch line).
Not relevant for me now as I ended up putting the supports in manually as generic models (already had the handrail in place separately) as my client needed it quickly.
I'd still be intrigued to see if anyone else has seen / solved this issue in the past though, in case I come across it again
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
wall railing for ramp
Wed, Dec 18, 2013 at 1:52:55 PM
Wall acting like railing
Fri, Sep 12, 2008 at 11:23:18 AM
Sloped railing along a wall
Sat, Oct 27, 2012 at 6:59:21 AM
single wall railing
Thu, Feb 16, 2006 at 4:44:19 PM
Page generation time: 0.5429
