Forums >> General Discussion >> Revit Project Management >> Material Image Gaps
Mon, Jul 4, 2016 at 1:01:53 PM | Material Image Gaps
kenzigolf18
Hello,
I am having an issue with there being lines in my materials when I create my own. I made sure that there were no gaps when I saved the picture of the image, but when I upload it into the manage materials, it creates a white line so that the material is not seamless. Is there a way to fix this issue?? I have attached a picture of what I am describing.
Thank you!!
Tue, Jul 5, 2016 at 9:41:07 AM | Material Image Gaps
Post the jpg material image by itself.... Not the Revit material.  We need to see the source.
Wed, Jul 6, 2016 at 12:10:14 PM | Material Image Gaps
kenzigolf18
It is doing it with any material I save and upload to Revit myself, but doesn't happen if I use a material in Revit already.
Thank you!
Wed, Jul 6, 2016 at 12:12:10 PM | Material Image Gaps
kenzigolf18
Here is another example
Wed, Jul 6, 2016 at 12:51:37 PM | Material Image Gaps
marmiketin1
4.5 Stars: 10 Votes
in both of your images there is a very thin white boarder around the actual meterial. you need to remove this and the image will be good to go.
I fixed the linen one for ya
Edited on: Wed, Jul 6, 2016 at 12:53:31 PM
Wed, Jul 6, 2016 at 12:57:26 PM | Material Image Gaps
kenzigolf18
Oh, that's a simple fix. Thank you so much!
How do I change the material image?
Thu, Apr 18, 2013 at 2:31:15 PM
Gaps is walls and corner [ 1 2 ]
Thu, Jan 12, 2017 at 12:19:52 PM
15
How to make Panels overlap Mullions & how to add gaps between those panels???
Sun, May 18, 2014 at 11:12:35 AM
Material image map problem
Mon, May 11, 2009 at 2:37:29 PM
Assigned a jpeg image to one material and other have it too
Fri, Jul 10, 2015 at 7:30:33 AM
Page generation time: 0.7955
