Forums >> Community >> Newbies >> Single Line - Laser Cut Export
Mon, Jul 4, 2016 at 6:17:19 AM | Single Line - Laser Cut Export
xcrogers
Perhaps (and most likely) a completely simple explanation, but is there a way to set up a view template whichd displays all walls as a single line (for export to laser cutting). We make a lot of models and it would vastly cut down on prep time if there was a way to streamline this export.
Thank you in adavance!
Tue, Jul 12, 2016 at 3:47:57 PM | Single Line - Laser Cut Export
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Make a wall type that's REALLY REALLY thin and swap them for the thicker walls ? The wall justification (in plan) will have an impact as well.
Sun, Jul 17, 2016 at 4:42:57 PM | Single Line - Laser Cut Export
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Sure, you're exporting it as CAD anyway right?
Is your laser cutter by color or by linetype?  Associate your wall's CAD linetype to the appropriate colors, hit save and away you go!  This will probably take some time since you're customizing the palatte, but you can easily save and export it to your other computers as well since you can "Load from..."
<see attached>
Cheers!
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Laser Scanning to REVIT
Thu, Dec 20, 2007 at 9:38:13 AM
whole project: walls, floors and roofs for laser cutting and building a physical
Tue, Jun 18, 2013 at 7:43:15 AM
Laserscanning Europe presents Laser Scanning TV
Tue, Nov 15, 2011 at 4:20:32 PM
export to CAD from isolated view
Fri, Aug 1, 2008 at 9:25:47 AM
Single line building line for site plan
Mon, Aug 17, 2015 at 8:15:57 PM
Page generation time: 1.9481
