Forums >> Revit Building >> Tips & Tricks >> How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"?
Tue, Jun 28, 2016 at 12:02:58 AM | How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"?
jebakumar
Hi,
Is there any way to locate the objects in the distance of "Half Equal, Equal, Equal, Half Equal"? We used to locate the diffusers in that way.
Thanks!!
Jebakumar
Tue, Jun 28, 2016 at 8:50:43 AM | How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"?
mansell5
3.5 Stars: 4 Votes
a workaround, but try this........
place seven objects that you want to use, dimension them then hit the EQ option.
THEN DELETE THE 1st, 3rd , 5th and seventh object, adjust dimension lines and hey presto.
the 2nd , 4th and 6th object will be spaced as you require.
Centering Elements WITHOUT using the "Equal" dimension
Mon, Nov 24, 2008 at 2:38:42 PM
EQUAL CONSTRAINT DIMENSION
Mon, Jan 10, 2005 at 1:06:29 PM
custom baluster with decorative piece not staying equal 2019
Thu, Jun 14, 2018 at 1:54:47 PM
No Equal Toggle for Arc Dimensions?!
Fri, Nov 6, 2015 at 2:57:13 PM
Dividing a section into equal parts
Sat, Jul 22, 2006 at 9:45:10 AM
Page generation time: 0.5771
