27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Turning off demolished walls
5 Posts No Rating |
I am a new user to Revit, my office is transferring from ADT to Revit and we have been using Revit for about 2 weeks.
My question is how do I turn off walls and other elements that have been demolished using the demolish tool. When rendering the building the demolished walls keep on showing up.
Thanks in advance.
You need to make sure when you're creating the existing conditiions that the phase under properties (at the very bottom of the properties dialog box) is set to existing. Then when you demo a wall and create your renderings you can set the properties of the phase to new construction and all your demo wall will go away. If you really think about what the application is doing....this is how it would happen in real life and this is exactly how the application acting.
5 Posts No Rating |
Thanks for your help... works like clockwork once you know how to do it. The more I use th program the more I like it.
Schedule or quantity for just demolished walls |
Wed, Sep 19, 2012 at 1:16:22 PM
Demolished walls hiding proposed stuff |
Tue, Sep 20, 2016 at 5:54:34 PM
MAKING DEMOLISHED OBJECTS TRANSPARENT |
Tue, Mar 12, 2013 at 2:02:34 PM
Demolished walls overlap furniture in plan. |
Mon, Nov 26, 2012 at 1:08:02 PM
Turning off certain elements in Visiblity Graphics (VG) |
Sat, Sep 9, 2006 at 6:12:07 AM
