Forums >> Revit Building >> Technical Support >> Renders with artificial lighting on result in high saturation and black patches
Mon, Jun 20, 2016 at 2:34:34 PM | Renders with artificial lighting on result in high saturation and black patches
LuxmyR
While rendering with artificial lights on, either in "Sun and Artificial" or "Artificial Only", resulting renders look like the attached image: intense saturation as points of highlight, and black patches as shadows.
When I try rendering to AutoDesk Cloud, the render works out fine. I've never experienced this problem, so I'm wondering if corruption to the project file is causing the issue.
Tue, Jun 21, 2016 at 7:29:28 PM | Renders with artificial lighting on result in high saturation and black patches
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
post render, you have slider bars which you can use to adjust exposure, Highlights, shadows, saturation, and such. That would be the palce to start.
LIGHTING W/ARTIFICIAL
Wed, Aug 6, 2008 at 11:13:16 PM
Lighting Fixtures show black in rendering but light in different angles
Tue, Jun 3, 2014 at 7:55:10 AM
Render exterior view with artificial lights - how to make interior glow?
Sun, Mar 11, 2012 at 12:45:28 PM
black screen and unfinished renders
Tue, Apr 21, 2009 at 7:28:17 PM
Revit always renders all of the lights
Fri, Aug 8, 2014 at 9:24:36 AM
Page generation time: 0.1614
