Forums >> Community >> Newbies >> masked components
Mon, Jun 20, 2016 at 12:31:50 PM | masked components
keithrickabaugh
How can I create a component that will mask whatever is behind it? send to back does not seem to work for this task.
Mon, Jun 20, 2016 at 1:01:06 PM | masked components
marmiketin1
4.5 Stars: 10 Votes
In the family the component is built in you have to go to each view and make sure all the visibility settings are setup correctly for viewing in plan, elevation, section and 3D. Also you may have to add masking regions to the views in the shape of the individual component parts of the model.
Mon, Jun 20, 2016 at 2:15:59 PM | masked components
You don't say what this component is.
  • A model component, if not transparent, will automatically mask model components behind it.
  • If it is a detail component, then you can add a masking region in the family.
  • Annotation elements can have masking text.
Placing an imported family over a masked region.
Tue, Nov 6, 2007 at 1:02:49 PM
changing Masked Region border lineweight
Mon, Feb 23, 2015 at 5:33:14 PM
Detail Components from Product Manufacturers?
Mon, Jun 14, 2010 at 12:43:51 PM
Masking not working on grid lines
Wed, Jul 22, 2009 at 1:53:07 PM
How do you eliminate the line showing around masking regions?
Fri, Aug 3, 2007 at 10:15:13 AM
Page generation time: 0.6898
