Forums >> Revit Building >> Technical Support >> Okay. Fine. I'm a n00b.
Tue, Apr 11, 2006 at 8:33:25 AM | Okay. Fine. I'm a n00b.
Jerzor
I'm a student using Revit for a modeling project. I'm trying to create a decent display model, but for some crazy reason I can't figure out how to change the color of the walls. How do you do it? Do you need to create a new wall type, and if so, how do you do that?
Tue, Apr 11, 2006 at 10:49:02 AM | RE: Okay. Fine. I'm a n00b.
quiller
quiller Avatar
2.5 Stars: 3 Votes
Best advise is to walk through a tuturial on walls, or get a revit manual. Or, go to the properties of the wall and change the apperaence under the wall structure......
Problem with 'Coarse' & 'Fine' view options
Thu, May 16, 2013 at 2:07:40 AM
Make Walls Grey and Transparent in Plan view 'Fine Detail'
Thu, Nov 3, 2011 at 7:30:56 AM
fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:20 PM
Fill Region not visable
Thu, Oct 5, 2006 at 3:46:48 PM
Deleting Families from project file
Thu, Nov 6, 2003 at 8:37:24 AM
Page generation time: 0.3918
