Forums >> General Discussion >> Revit Project Management >> Plan Regions
Fri, Jun 17, 2016 at 12:05:54 PM | Plan Regions
thinkpositive
5 Stars: 7 Votes
Arn't plan regions just supposed to change the view range of a portion in the plan? I ma working on a project where I created a plan region for a part of the plan to be able to set the cut plan to about 8'-0". The rest of the plan has the cut plan at 4'-0". The problem is that the rooms and room tags withing the plan region start showing errors and revit says "Room tag is outside the room." I dont understand why changing the cut plane would cause any change to the room tag.
Fri, Jun 17, 2016 at 12:19:02 PM | Plan Regions
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'd just raise the height of the room objects to be cut within the plan region. If the room isn't being cut in the view the tag can't identify it right. Create a section, turn on the room fill and investigate the cut plane vs the room height.
Fri, Jun 17, 2016 at 12:46:20 PM | Plan Regions
thinkpositive
5 Stars: 7 Votes
Aah.. I see it now. You are right. My room height was the problem. Thanks for the help.
Fri, Jun 17, 2016 at 12:50:11 PM | Plan Regions
thinkpositive
5 Stars: 7 Votes
It is funny thought. I would think Revit should be able to pick up the volume of the room on it's own. Any room height more than 8'-0" has to be manually adjusted as by default it assigns 8-0" height to the room and not upto the bottom of the ceiling/floor.
Plan Regions Cutting Stairs
Thu, May 26, 2011 at 6:14:12 PM
Plan regions
Thu, Jan 28, 2016 at 6:33:35 PM
Full edit capabilities insiide plan region
Thu, Dec 8, 2005 at 4:13:57 AM
Oh Plan Regions, you vex me so...
Mon, Nov 26, 2012 at 11:02:41 AM
room name in relation with plan regions
Fri, Sep 16, 2011 at 9:29:48 AM
Page generation time: 1.9864
