Forums >> Revit Building >> Technical Support >> Combine Discipline
Fri, Jun 17, 2016 at 4:23:10 AM | Combine Discipline
sonictank84
Hi everyone!
I've M&E drawing, split into categories as Electric, Plumbing, HVAC .How i could combine all categories in one Drawing (by name Combine)in project!
Fri, Jun 17, 2016 at 7:20:59 AM | Combine Discipline
marmiketin1
4.5 Stars: 10 Votes
By split into "categories" do you mean they are in seperate revit files as seperate models. If so just link the revit models into one main model using shared coordiantes.
Fri, Jun 17, 2016 at 7:33:07 AM | Combine Discipline
sonictank84
Yes i split file revit into "Electric ,Plumbing, HVAC file" .Now, i want combine all into one file" combine name"include (electric,Plumbing,Hvac).Can you guide do it.where's it in categories?
Edited on: Fri, Jun 17, 2016 at 7:42:37 AM
Fri, Jun 17, 2016 at 11:09:52 AM | Combine Discipline
Typically we would never do this because these are best kept seperate but linked together to show what is needed in each discipline.
Fri, Jun 17, 2016 at 5:14:15 PM | Combine Discipline
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
After you Link in the REVIT models select one, and click 'Bind Link'. That turns it into a group. Then select the group and ungroup it and now you have everything living in the same file.
Fri, Jun 17, 2016 at 6:54:42 PM | Combine Discipline
sonictank84
Yes..but how i can copy system electric,pipe system,duct system into a combine drawing?because when inserted link revit ,all system wouldn't copy into new project.
where are my walls??
Thu, Apr 2, 2009 at 10:51:30 PM
Sub Discipline under Views?
Fri, Apr 17, 2009 at 2:21:21 PM
Drawing Index order
Mon, Apr 20, 2009 at 5:26:40 PM
Can't find Sub-Discipline in Properties
Mon, Jan 27, 2014 at 5:24:22 AM
Controlling Display setting per Discipline
Fri, Feb 17, 2012 at 12:33:04 PM
Page generation time: 3.8412
