15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> residentail railing to past post
REVIT 2016
Can't get a residentail railing to end at the post as needed. See attached pdf. Need the hand rail to extend slightly past the post.
Thanks,
JK
If just that top portion is the handrail, the handrail can be sketched to do that. Another option is to use a handrail termination.
rail extension path
- Select the rail with the extension you wish to modify.
- On the Continuous Rail panel, click
(Edit Rail).
- On the Tools panel, click
(Edit Path).
- Optionally, display the Workplane Viewer and use the drawing tools to modify the extension path. See Define a Continuous Rail Extension.
Still have not gotten anywhere with this. I don't understand your answer.
I don't see and "edit rail" button to click on. I have attacvhed a revit file   REVIT 17 LT) of the offending railing.
Thanks,
JK
See pictures. I hope it works in 2017 LT as well.
Pijpiwo - Thank so much for the help! Your post bridged the gap, the screen shots were great.
Yes, it did work the same way with LT.
Cheers!
extend railing past end post. |
Wed, Dec 30, 2009 at 5:00:04 PM
Railing Post Visibility Issues |
Tue, Oct 2, 2012 at 3:51:35 PM
making railing post show |
Fri, Jan 18, 2013 at 1:39:35 PM
Custom railing panel extends past corners. |
Wed, Jul 14, 2010 at 11:40:26 AM
railing at post issue |
Fri, May 22, 2009 at 9:40:40 AM
