Forums >> General Discussion >> Revit Project Management >> How to take quantities from painted surfaces?
Wed, Jun 15, 2016 at 2:53:42 AM | How to take quantities from painted surfaces?
JoeHands
Hi,I would like to take out the quantity of the painted surfaces in a project. I have considered using the "paint" tool and pain all the surfaces. However some of the wall are not painted all the way to each floor partition, because of suspended ceilings. Whats the work around that? Or do you have any other suggestions?
Thu, Jun 16, 2016 at 6:07:47 AM | How to take quantities from painted surfaces?
You would have to use the split face tool to  paint the correct area then use the materials take off.  If all of your walls are the same, you can build your wall type with a split in your finish face at a set elevation.
Mon, Jul 4, 2016 at 2:43:13 AM | How to take quantities from painted surfaces?
JoeHands
Thanks - That solved it
Mon, Oct 9, 2017 at 2:27:37 PM | How to take quantities from painted surfaces?
rfeineis
rfeineis Avatar
Try using the Revit Roombook plugin. It is availalbe via Subscription.
Rick Feineis, CTT+, AAI
Managing Partner
CAD Training Online
(757) 619-3614
www.cadtrainingonline.com
Tue, Oct 10, 2017 at 1:00:43 AM | How to take quantities from painted surfaces?
charlesjohny8
Use the extension name colorzilla for taking quantity of painted surfaces.
Revit 2014 . rendering in cloud . painted surfaces
Mon, Feb 23, 2015 at 4:13:00 PM
Angular surfaces
Fri, Oct 16, 2009 at 2:23:30 PM
Painted surfaces
Wed, Jul 17, 2013 at 10:06:53 AM
painted split face doesn't show in dependent view
Mon, Nov 1, 2010 at 12:32:13 PM
Really Odd Perspective/3D problem
Wed, Apr 29, 2015 at 7:53:09 AM
Page generation time: 0.2859
