Forums >> Revit Building >> Technical Support >> how to underlay a plan in a duplacated plan
Sun, Jun 12, 2016 at 8:16:47 AM | how to underlay a plan in a duplacated plan
chengran
3 Stars: 3 Votes
Look the attached pic, Thanks.
Mon, Jun 13, 2016 at 8:28:31 AM | how to underlay a plan in a duplacated plan
marmiketin1
4.5 Stars: 10 Votes
Underlay is controlled in properties not visibility graphics.
Mon, Jun 13, 2016 at 9:44:17 AM | how to underlay a plan in a duplacated plan
chengran
3 Stars: 3 Votes
Mon, Jun 13, 2016 at 10:51:05 AM | how to underlay a plan in a duplacated plan
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
chengran,
Says you joined RevitCity in December 2014, you asking us to tell you how to put an underlay on? The parameter/drop down is clearly visiable on your second picture... currently set to "None"? or is there something more to your question? If so, please explain otherwise members won't be able to assist you.
As WWHub would say, 'garbage in = garbage out'
Thanks,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Mon, Jun 13, 2016 at 12:12:56 PM | how to underlay a plan in a duplacated plan
chengran
3 Stars: 3 Votes
Even you select NONE, all the elements such as WALLS WINDOWS  are underlayed in a duplicated plan. I do not know why
Mon, Jun 13, 2016 at 12:16:06 PM | how to underlay a plan in a duplacated plan
chengran
3 Stars: 3 Votes
I could not select them unless  select potion are changed.
Mon, Jun 13, 2016 at 12:49:40 PM | how to underlay a plan in a duplacated plan
marmiketin1
4.5 Stars: 10 Votes
It must have to do with your view range settings. They are probably set to the level below for bottom clip instead of associated level. View range is found in the view properties at the bottom.
Mon, Jun 13, 2016 at 2:27:25 PM | how to underlay a plan in a duplacated plan
chengran
3 Stars: 3 Votes
Have nothing to do with the view range. There are only two leves and the view ranges are same.
Mon, Jun 13, 2016 at 2:33:45 PM | how to underlay a plan in a duplacated plan
chengran
3 Stars: 3 Votes
the view range of floor and duplicated plans are same.
Tue, Jun 14, 2016 at 4:23:52 AM | how to underlay a plan in a duplacated plan
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Chengran,
So, you duplicated a plan and in your duplicated plan you can see the level below but on the original plan you could not see the level below and you are wondering why this is occurring and how it be fixed so that the plan below is not visiable?
Anyway, so you have duplicted the plan and changed nothing what so ever? Have you tried duplicating the plan again?  I came across something similar where I duplicated a first floor view and applied a different View Template and for some reason i could see the ground floor walls, doors, windows, WC's etc. yet the rooms were still bound to where the first floor walls would have been and my content and my first floor furniture was visiable yet my ground floor furniture was not... very strange.
Anyway, I remade the template and then it was happy, I read that sometimes the "associated" level can get confused when it is applied to a different level from which is was created. I say sometimes as I've been doing it for years and that was the only time its ever occurred.
Hope this helps.
Shatner86
-Albert Einstein
Tue, Jun 14, 2016 at 10:24:59 AM | how to underlay a plan in a duplacated plan
#11
chengran
3 Stars: 3 Votes
Yes, all the elements in original plan are underlayed in new duplicate plan, not halftone, not  underlay any level or plan. For small project this skill is very helpful. You do need to link a model.....
Tue, Jun 14, 2016 at 10:27:27 AM | how to underlay a plan in a duplacated plan
#12
chengran
3 Stars: 3 Votes
I try to set a View Template, but I do not know how to underlay elements in the View Template, instead of halftone...
Underlay in Site Plan
Fri, Aug 6, 2010 at 8:26:01 AM
Underlay.... problems
Tue, Jul 31, 2007 at 11:36:03 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
misguided underlay
Tue, Feb 19, 2013 at 8:14:29 AM
Ceiling plan as underlay
Fri, May 27, 2011 at 3:41:15 AM
Page generation time: 3.4246
