Forums >> Revit Building >> Technical Support >> How to differentiate two types in a family that look the same in elevation?
Thu, Jun 9, 2016 at 6:27:22 PM | How to differentiate two types in a family that look the same in elevation?
BriDS
I have created a family of blocks.  Two of the types look identical in elevation, but I need to be able to tell the difference between them. They are simple blocks (cubes), two of them are the same size, but one is used only at the ends of walls (think of concrete blocks). I need to differentiate between them for counting puposes.  If they look the same, the margin for error goes up huge.  If the end blocks could have an E or something to tell them apart I would be very happy.  Any suggestions on how to do this?
Thu, Jun 9, 2016 at 6:29:55 PM | How to differentiate two types in a family that look the same in elevation?
BriDS
I'm using version 2016
Thu, Jun 9, 2016 at 8:22:15 PM | How to differentiate two types in a family that look the same in elevation?
CDWdavid
5 Stars: 5 Votes
The simplist way is using the invisible lines to add a mark into the family for the end piece.
In the project, you can just have your cursor hovering the family, the invisible line mark will be shown in blue.
Fri, Jun 10, 2016 at 7:15:08 AM | How to differentiate two types in a family that look the same in elevation?
marmiketin1
4.5 Stars: 10 Votes
If you want a letter to appear for the end block type you can just put text or a label into the family and then have a visibility type parameter and turn it on only for the end block. If you use a label you can have the letter be different for all the types instead of just turning it on or off
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:50 PM
Lines from different wall types showing up in elevation
Tue, Sep 24, 2013 at 10:07:46 PM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
Family types problem.
Tue, Apr 21, 2009 at 10:00:20 AM
Creating Family types which differ in fatures in the model
Wed, May 23, 2012 at 7:56:37 AM
Page generation time: 2.3595
