Forums >> Revit Building >> Technical Support >> Door tag that shows to our from room
Thu, Jun 9, 2016 at 5:47:59 PM | Door tag that shows to our from room
SVM1Steve
Hay all,
Currently using 2016, we don't typically do a door or window schedule but rather call out or tag the doors in plan/section.  I know that I can set a schedule that will display the to/from room names. What I need is to be able to have this done in a tag for sections. Couple things are is this possible and what would be the procedures for making it happen?  Thanks in advance.
Fri, Jun 10, 2016 at 9:22:03 AM | Door tag that shows to our from room
marmiketin1
4.5 Stars: 10 Votes
Best practice would be to just have a schedule. They are far easier to read then searching through plans for each and every door. Currently there is no way to have a parameter that automatically fills in the room name for which the door opens into. There are some 3rd party add ins that can do this i believe. I think your best bet tho would be to just tag the rooms in your sections.
Another way would be to add a parameter to all your door families which references the shared parameter for room name and then you would have to add a label to your door tage families that references that same shared parameter. You would still then have to make sure the proper room is indicated in your door to get the right room name in the tag so really it is not worth it doing it as you still have to do things manually.
Schedules are the way to go. Hope this helped in some way.
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
Associating Door Tag Labels to Room Tag Labels for Automated Door Schedule?
Wed, May 13, 2009 at 3:16:32 PM
Adding Room Number to Door Tag
Sun, Jun 23, 2013 at 9:14:46 AM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Visibility elements in a room tag
Mon, Aug 9, 2010 at 2:58:33 PM
Page generation time: 0.5444
